PCV valves.... posted by Paulym1111 on April 04, 2011 at 08:04 PM
really paulm1111? you think its the PCV valves?....that'd be amazing if that was it....when first started it doesn't smoke bad....smells more of a fuel smell bc it is running rich....but when i drive it and boost it then release the throttle it smokes bluish/white...then after driving it if i stop and let it idle it is just a large amount of white smoke and u can tell it has an oil smell to it! the turbos are brand new...so i really doubt its those! last time i checked the engines cylinder compression tests came back pretty low...so i was thinking i was getting some blow-by...but i didn't think blow by would make it smoke this bad...
